DarienAL
Mar 24, 2020Tutor
XRM570 - separate SSID = separate networks?
If I utilize the ability of the XRM570 to have separate SSID's for my 2.4 and 5ghz bands are those actually isolated networks? Can devices/resources on one network see those on the other and can devi...
Netduma-Fraser
Mar 24, 2020NetDuma Partner
They're not isolated because it is all apart of your local network and they will all be on the same subnet 192.168.1.x for example.
DarienAL
Mar 24, 2020Tutor
Thanks
