Carnaged
Sep 22, 2020Tutor
XRM570 iPhone disconnects from WiFi.
Hi, I have noticed that sometimes even when my iPhone has good signal strength, between 2/3 bars it will randomly drop the WiFi and go to 4G. I have the 2.4ghz and 5ghz seperat3d and usually keep my...
Netduma-Fraser
Sep 22, 2020NetDuma Partner
Okay using a DFS channel isn't great and could be the issue. Go to the next best non DFS channel and see if that works. It should switch to the next strongest signal that it can.
Sep 22, 2020Guru - Experienced User
What is the distance between the XR router and the XR7700 extender. 30 feet or more is recommended between the XR router and EX extender.
