Carnaged
Sep 04, 2020Tutor
XRM570 new user issues?
Hi all, I received this system yesterday and set it up, I ran into some teething troubles and thought I would ask about them here. 1.) The devices tab in the Nighthawk Router App doesn't work...
Netduma-Fraser
Sep 04, 2020NetDuma Partner
I can't advise on the app unfortunately as we didn't work on that. Change your DNS in Internet Setup and see if that helps with the loading issues. You can see link speed in the Device Manager table view.
Carnaged
Sep 04, 2020Tutor
Hi, I beleive you replied to me on your forums also, I posted this on both.
That was my first thought so I changed from my ISP DNS to Cloudflare and then tried again. Still didn't work but like I said, did work on my phone 4G.
- Netduma-FraserSep 04, 2020NetDuma PartnerPerhaps there is a port conflict, in WAN Settings switch NAT to Open, does that help?
- CarnagedSep 05, 2020Tutor
Netduma-Fraser wrote:
Perhaps there is a port conflict, in WAN Settings switch NAT to Open, does that help?If it happens again I will do that, at the moment all webpages are working fine, including DSLReports.
