conkerick
May 19, 2021Tutor
XRM570 Wifi DHCP Issue
Hi, since I bought the XRM570 (XR500) I am having this issue: From time to time, randomly, the router does not assign an IP address over WiFi. The devices indicate "could not assign or get an ip ...
conkerick
Jul 21, 2021Tutor
Hi, sorry for the delay. The problem had not occurred again until yesterday.
The "Traffic Controller" tip doesn't do anything.
All my WiFi devices are like this:
If I see the router log, it has too many DHCP requests from my devices (they all have reserved ip's). They happen almost every second.
Rebooting the router from the interface, it worked. All WiFi devices work without problem.
Today I was working on my PC (connected via cable) and suddenly, I lost the Internet connection. The error that I got was "dns server is not responding". My DNS server is 192.168.8.1 (my router), which points to 8.8.8.8.
My wife was using the tv connected to wifi without any problem.
Trying to manually configure the 8.8.8.8 dns server on my pc, I got the same error.
I tried to open 192.168.8.1 in the browser it said "the server is not responding".
Then in cmd "ipconfig / release and ipconfig / renew" and I got this:
"The DHCP server timed out."
I thought that the problem was only in WiFi, but it turns out that it also happens by cable, only that my pc had a reserved IP and a fixed IP.
At that moment my wife tells me that she does not have WiFi on her phone or on the TV. When I check, no device could connect to WiFi, my computer (only device connected by cable) could not connect either.
So DHCP issue is general, but it is the first time that the router freeze completely .
I had to unplug it from the wall and plug it back in. Everything works correctly.
One thing that I have noticed is that only the power led is on, no matter which option I choose in the interface. There isn't any blinking led.
Thanks. Hopefully you can help me.
Netduma-Liam
Jul 22, 2021NetDuma Partner
Thanks for the detail, I'm unable to see the screenshots you've provided yet as they presumably need to be moderated.
There isn't currently a known issue with DHCP on the Nighthawk Pro Gaming routers, however it's quite rare relative to the amount of users. Netgear are aware of this and have been investigating it for some time, from my understanding the cause of the problem is known so it's a case of fixing that now.
It's interesting that this issue crops up for you on a seemingly monthly basis, that would suggest to me that the issue isn't occuring because of a lease expiry.
Have you experienced this on all firmware's or did this only occur from .114 onwards?
- conkerickJul 22, 2021Tutor
Hi, the screenshots has been moderated and are visible now.
It happens in version 114 and 120. I'm using the .120 version as suggested and still having the issue.
At the time of posting this, everything was working normal until I lost internet connection on all my devices, wired and WiFi.
I ran to my computer to check if the issue was the same but I found the extender lost communication with the router:
Router Link LED: OFF
Can't access or ping the router (from my pc which is wired) and a few seconds later the extender was like this:
Router Link LED: RED
Then I was able to access and ping the router. Few seconds later the Router Link LED was solid white.
In the "System information" I saw that uptime was "4 min", so... it rebooted itself (or maybe crashed?). It had never happened to me or maybe I never noticed. Is this normal behavior?
As I said above, in firmware .120 the led from the router don't work as before, they don't blink. Only the power led is on. Is this normal?
Thank you for your answer.
- Netduma-LiamJul 23, 2021NetDuma Partner
Are all devices connected to the extender? Are devices that aren't connected to the extender getting these issues too?
It does sound like the router has rebooted itself, that's not normal but it is symptomatic of this issue. Do the lights blink when the router is functioning as expected or are they never showing any activity?
- conkerickJul 23, 2021Tutor
Hi,
There are 37 wifi devices in my house (smart switches, smart devices, smart cameras, tv, etc.) according to the router. 20 of them are connected through the extender.
First time that I noticed a reboot.
The lights do not blink despite network activity (all devices connected, watching YouTube, playing games, etc.). This happened in update .120, in .114 the lights were working properly.
Thank you.
- Netduma-FraserJul 23, 2021NetDuma PartnerWhat is the model of the modem/router the XR is connected to?
Huawei EG814V5.
Thank you.
To add a bit more information, since yesterday's reboot, the log is full of this entries:
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:06:53 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Friday, July 23, 2021 20:06:53 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Friday, July 23, 2021 20:06:53 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:06:53 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:06:53 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:06:53 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:06:53 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:06:53 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:06:53 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:06:53 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:06:53 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:06:53 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:06:53 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:06:53 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:06:53 [DumaOS] recovering state com.netdumasoftware.dpiclass, Friday, July 23, 2021 20:06:51 [DumaOS] process '/usr/bin/dpiclass' died restart:true, Friday, July 23, 2021 20:06:51 [DumaOS] recovering state com.netdumasoftware.dpiclass, Friday, July 23, 2021 20:06:51 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Friday, July 23, 2021 20:02:24 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Friday, July 23, 2021 20:02:24 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:24 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:24 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:24 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:24 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:24 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:24 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:24 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:24 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:24 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:24 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:24 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:24 [DumaOS] process '/usr/bin/dpiclass' died restart:true, Friday, July 23, 2021 20:02:22 [DumaOS] recovering state com.netdumasoftware.dpiclass, Friday, July 23, 2021 20:02:22 [DumaOS] recovering state com.netdumasoftware.dpiclass, Friday, July 23, 2021 20:02:22 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Friday, July 23, 2021 20:02:12 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Friday, July 23, 2021 20:02:12 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:12 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:12 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:12 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:12 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:12 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:12 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:12 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:12 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:12 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:12 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:12 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:02:12 [DumaOS] process '/usr/bin/dpiclass' died restart:true, Friday, July 23, 2021 20:02:10 [DumaOS] recovering state com.netdumasoftware.dpiclass, Friday, July 23, 2021 20:02:10 [DumaOS] recovering state com.netdumasoftware.dpiclass, Friday, July 23, 2021 20:02:10 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Friday, July 23, 2021 20:01:46 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Friday, July 23, 2021 20:01:46 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:01:46 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:01:46 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:01:46 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:01:46 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:01:46 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:01:46 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:01:46 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:01:46 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:01:46 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:01:46 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:01:46 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Friday, July 23, 2021 20:01:46 [DumaOS] recovering state com.netdumasoftware.dpiclass, Friday, July 23, 2021 20:01:46 [DumaOS] recovering state com.netdumasoftware.dpiclass, Friday, July 23, 2021 20:01:44 [DumaOS] process '/usr/bin/dpiclass' died restart:true, Friday, July 23, 2021 20:01:44 [DumaOS] Marking device that is marked 192.168.8.60 44 35., Friday, July 23, 2021 20:00:34
A new reboot has occurred at the same time that yesterday:
[DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pending, Saturday, July 24, 2021 00:17:22 [DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pending, Saturday, July 24, 2021 00:17:22 [DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pending, Saturday, July 24, 2021 00:17:22 [DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pending, Saturday, July 24, 2021 00:17:22 [DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pending, Saturday, July 24, 2021 00:17:22 [DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pending, Saturday, July 24, 2021 00:17:22 [DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pending, Saturday, July 24, 2021 00:17:22 [DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pending, Saturday, July 24, 2021 00:17:22 [DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pending, Saturday, July 24, 2021 00:17:22 [DumaOS] Ubus object 'com.netdumasoftware.trafficcontroller' added, attempting to bind pending, Saturday, July 24, 2021 00:17:22 [DumaOS] installing 'S21-Rule', Saturday, July 24, 2021 00:17:22 [DumaOS] config write 'com.netdumasoftware.qos.settings', Saturday, July 24, 2021 00:17:21 [DumaOS] Dependency loaded 'com.netdumasoftware.devicemanager', Saturday, July 24, 2021 00:17:21 [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pending, Saturday, July 24, 2021 00:17:21 [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pending, Saturday, July 24, 2021 00:17:21 [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pending, Saturday, July 24, 2021 00:17:21 [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pending, Saturday, July 24, 2021 00:17:21 [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pending, Saturday, July 24, 2021 00:17:21 [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pending, Saturday, July 24, 2021 00:17:21 [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pending, Saturday, July 24, 2021 00:17:21 [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pending, Saturday, July 24, 2021 00:17:21 [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pending, Saturday, July 24, 2021 00:17:21 [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pending, Saturday, July 24, 2021 00:17:21 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Saturday, July 24, 2021 00:17:19 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Saturday, July 24, 2021 00:17:19 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Saturday, July 24, 2021 00:17:19 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Saturday, July 24, 2021 00:17:19 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Saturday, July 24, 2021 00:17:19 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Saturday, July 24, 2021 00:17:19 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Saturday, July 24, 2021 00:17:19 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Saturday, July 24, 2021 00:17:19 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Saturday, July 24, 2021 00:17:19 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Saturday, July 24, 2021 00:17:19 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Saturday, July 24, 2021 00:17:19 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Saturday, July 24, 2021 00:17:19 [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Saturday, July 24, 2021 00:17:19 [DumaOS] Cloudsync DPI result 'nil','failed to sync', Saturday, July 24, 2021 00:17:19 [DumaOS] Cloudsync DPI 'skipping mirror', Saturday, July 24, 2021 00:17:19 [DumaOS] Cloudsync DPI 'HTTP sync failed', Saturday, July 24, 2021 00:17:19 [DumaOS] HTTP download failed with code '404', Saturday, July 24, 2021 00:17:19 [DumaOS] DHCP new lease allocated., Saturday, July 24, 2021 00:17:18 [DumaOS] DHCP new event., Saturday, July 24, 2021 00:17:18 [DHCP IP: 192.168.8.41] to MAC address 98:da:c4:c8:27:57, Saturday, July 24, 2021 00:17:18 [DumaOS] config write 'com.netdumasoftware.devicemanager.database', Saturday, July 24, 2021 00:17:15 [DumaOS] DHCP new lease allocated., Saturday, July 24, 2021 00:17:15 [DumaOS] DHCP new event., Saturday, July 24, 2021 00:17:15 [DHCP IP: 192.168.8.31] to MAC address 24:62:ab:1a:bb:95, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.autoadmin' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] App 'com.netdumasoftware.config' initialised & starting., Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' now bound, Saturday, July 24, 2021 00:17:15 [DumaOS] Dependency loaded 'com.netdumasoftware.config', Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' now bound, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Dependency loaded 'com.netdumasoftware.config', Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.config' added, attempting to bind pending, Saturday, July 24, 2021 00:17:15 [DumaOS] Config Changed: DumaOS_Public_IP, Saturday, July 24, 2021 00:17:15 [DumaOS] Ubus object 'com.netdumasoftware.autoadmin' added, attempting to bind pending, Saturday, July 24, 2021 00:17:14 [DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending, Saturday, July 24, 2021 00:17:14 [DumaOS] App 'com.netdumasoftware.autoadmin' initialised & starting., Saturday, July 24, 2021 00:17:14 [DumaOS] Dependency loaded 'com.netdumasoftware.autoadmin', Saturday, July 24, 2021 00:17:14 [DumaOS] Ubus object 'com.netdumasoftware.autoadmin' added, attempting to bind pending, Saturday, July 24, 2021 00:17:14 [DumaOS] Ubus object 'com.netdumasoftware.autoadmin' added, attempting to bind pending, Saturday, July 24, 2021 00:17:14 [DumaOS] All dependencies loaded, starting, Saturday, July 24, 2021 00:17:14 [DumaOS] Dependency loaded 'com.netdumasoftware.autoadmin', Saturday, July 24, 2021 00:17:14 [DumaOS] Ubus object 'com.netdumasoftware.autoadmin' added, attempting to bind pending, Saturday, July 24, 2021 00:17:14 [DumaOS] Ubus object 'com.netdumasoftware.autoadmin' added, attempting to bind pending, Saturday, July 24, 2021 00:17:14 [DumaOS] Ubus object 'com.netdumasoftware.autoadmin' added, attempting to bind pending, Saturday, July 24, 2021 00:17:14 [DumaOS] Dependency loaded 'com.netdumasoftware.autoadmin', Saturday, July 24, 2021 00:17:14 [DumaOS] Ubus object 'com.netdumasoftware.autoadmin' added, attempting to bind pending, Saturday, July 24, 2021 00:17:14 [DumaOS] Ubus object 'com.netdumasoftware.autoadmin' added, attempting to bind pending, Saturday, July 24, 2021 00:17:14 [DumaOS] Dependency loaded 'com.netdumasoftware.autoadmin', Saturday, July 24, 2021 00:17:14 [DumaOS] Ubus object 'com.netdumasoftware.autoadmin' added, attempting to bind pending, Saturday, July 24, 2021 00:17:14 [DumaOS] Ubus object 'com.netdumasoftware.autoadmin' added, attempting to bind pending, Saturday, July 24, 2021 00:17:14 [DumaOS] Cloudsync Globals result 'true','Cloud is up to date', Saturday, July 24, 2021 00:17:14 [DumaOS] App 'com.netdumasoftware.qos' initialised & starting., Saturday, July 24, 2021 00:17:14 [DumaOS] Waiting for 'com.netdumasoftware.config' to run before starting, Saturday, July 24, 2021 00:17:14 [DumaOS] Waiting for 'com.netdumasoftware.autoadmin' to run before starting, Saturday, July 24, 2021 00:17:14 [DumaOS] Waiting for 'com.netdumasoftware.devicemanager' to run before starting, Saturday, July 24, 2021 00:17:14 [DumaOS] pending subscription for package 'com.netdumasoftware.config', Saturday, July 24, 2021 00:17:14 [DumaOS] pending subscription for package 'com.netdumasoftware.devicemanager', Saturday, July 24, 2021 00:17:14 [DumaOS] App 'com.netdumasoftware.geofilter' initialised & starting., Saturday, July 24, 2021 00:17:14 [DumaOS] Waiting for 'com.netdumasoftware.autoadmin' to run before starting, Saturday, July 24, 2021 00:17:14 [DumaOS] Waiting for 'com.netdumasoftware.devicemanager' to run before starting, Saturday, July 24, 2021 00:17:14 [DumaOS] pending subscription for package 'com.netdumasoftware.dpiclass', Saturday, July 24, 2021 00:17:14 [DumaOS] pending subscription for package 'com.netdumasoftware.devicemanager', Saturday, July 24, 2021 00:17:14 [DumaOS] App 'com.netdumasoftware.pingheatmap' initialised & starting., Saturday, July 24, 2021 00:17:13 [DumaOS] Waiting for 'com.netdumasoftware.geofilter' to run before starting, Saturday, July 24, 2021 00:17:13 [DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending, Saturday, July 24, 2021 00:17:13 [DumaOS] App 'com.netdumasoftware.desktop' initialised & starting., Saturday, July 24, 2021 00:17:13 [DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending, Saturday, July 24, 2021 00:17:13 [DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending, Saturday, July 24, 2021 00:17:13 [DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending, Saturday, July 24, 2021 00:17:13 [DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending, Saturday, July 24, 2021 00:17:13 [DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending, Saturday, July 24, 2021 00:17:13 [DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending, Saturday, July 24, 2021 00:17:13 [DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending, Saturday, July 24, 2021 00:17:13 [DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending, Saturday, July 24, 2021 00:17:13 [DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending, Saturday, July 24, 2021 00:17:13 [DumaOS] config write 'com.netdumasoftware.desktop.notification', Saturday, July 24, 2021 00:17:13 [DumaOS] Backing up settings to config partition., Saturday, July 24, 2021 00:17:13 [DumaOS] No settings file, restoring., Saturday, July 24, 2021 00:17:13 [DumaOS] App 'com.netdumasoftware.benchmark' initialised & starting., Saturday, July 24, 2021 00:17:13 [DumaOS] Waiting for 'com.netdumasoftware.config' to run before starting, Saturday, July 24, 2021 00:17:13 [DumaOS] Waiting for 'com.netdumasoftware.qos' to run before starting, Saturday, July 24, 2021 00:17:13 [DumaOS] pending subscription for package 'com.netdumasoftware.config', Saturday, July 24, 2021 00:17:13 [DumaOS] App 'com.netdumasoftware.devicemanager' initialised & starting., Saturday, July 24, 2021 00:17:13 [DumaOS] Waiting for 'com.netdumasoftware.autoadmin' to run before starting, Saturday, July 24, 2021 00:17:13 [DumaOS] pending subscription for package 'com.netdumasoftware.dpiclass', Saturday, July 24, 2021 00:17:13 [DumaOS] pending subscription for package 'com.netdumasoftware.deviceclass', Saturday, July 24, 2021 00:17:13 [DumaOS] subscribe to 'com.netdumasoftware.neighwatch' from 'com.netdumasoftware.devicemanager, Saturday, July 24, 2021 00:17:13 [DumaOS] The selected theme does not exist: 'default', Saturday, July 24, 2021 00:17:13 [DumaOS] Theme path does match manifest 'default', Saturday, July 24, 2021 00:17:13 [DumaOS] Cloudsync Themes result 'false','All mirrors are down', Saturday, July 24, 2021 00:17:13 [DumaOS] App 'com.netdumasoftware.trafficcontroller' initialised & starting., Saturday, July 24, 2021 00:17:13 [DumaOS] Waiting for 'com.netdumasoftware.devicemanager' to run before starting, Saturday, July 24, 2021 00:17:13 [DumaOS] Waiting for 'com.netdumasoftware.autoadmin' to run before starting, Saturday, July 24, 2021 00:17:13 [DumaOS] pending subscription for package 'com.netdumasoftware.devicemanager', Saturday, July 24, 2021 00:17:13 [DumaOS] Theme path does match manifest 'default', Saturday, July 24, 2021 00:17:13 [DumaOS] App 'com.netdumasoftware.hybridvpn' initialised & starting., Saturday, July 24, 2021 00:17:11 [DumaOS] Waiting for 'com.netdumasoftware.autoadmin' to run before starting, Saturday, July 24, 2021 00:17:11 [DumaOS] Waiting for 'com.netdumasoftware.devicemanager' to run before starting, Saturday, July 24, 2021 00:17:11 [DumaOS] pending subscription for package 'com.netdumasoftware.devicemanager', Saturday, July 24, 2021 00:17:11 [DumaOS] Ubus object 'com.netdumasoftware.networkmonitor' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] App 'com.netdumasoftware.networkmonitor' initialised & starting., Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.networkmonitor' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.networkmonitor' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.networkmonitor' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.networkmonitor' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.neighwatch' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.systeminfo' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] App 'com.netdumasoftware.neighwatch' initialised & starting., Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.neighwatch' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.neighwatch' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.neighwatch' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] DHCP new lease allocated., Saturday, July 24, 2021 00:17:10 [DumaOS] DHCP new event., Saturday, July 24, 2021 00:17:10 [DumaOS] DHCP new lease allocated., Saturday, July 24, 2021 00:17:10 [DumaOS] DHCP new event., Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.systeminfo' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] App 'com.netdumasoftware.systeminfo' initialised & starting., Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.systeminfo' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.systeminfo' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] subscribe to 'com.netdumasoftware.arpwatch' from 'com.netdumasoftware.neighwatch', Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.internetmeasurer' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] App 'com.netdumasoftware.internetmeasurer' initialised & starting., Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.internetmeasurer' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] Ubus object 'com.netdumasoftware.procmanager' added, attempting to bind pending, Saturday, July 24, 2021 00:17:10 [DumaOS] App 'com.netdumasoftware.procmanager' initialised & starting., Saturday, July 24, 2021 00:17:10 [DumaOS] Non-existent publish method 'licence_permitted', Saturday, July 24, 2021 00:17:10 [DoS Attack: ACK Scan] from source: 31.13.67.32, port 443, Saturday, July 24, 2021 00:17:09 [DumaOS] Starting process manager, Saturday, July 24, 2021 00:17:09 [Time synchronized with NTP server] Saturday, July 24, 2021 00:17:00 [DoS Attack: ACK Scan] from source: 31.13.67.32, port 443, Saturday, July 24, 2021 00:16:52 [Internet connected] IP address: 172.16.0.2, Saturday, July 24, 2021 00:16:47 [Dynamic DNS] host name 0.0.0.0 registeration failure, Saturday, July 24, 2021 00:16:40 [Initialized, firmware version: V2.3.2.120] Saturday, July 24, 2021 00:16:34
Yesterday was: [Initialized, firmware version: V2.3.2.120] Saturday, July 23, 2021 00:18:37
- Netduma-FraserJul 24, 2021NetDuma PartnerThanks for that, copy the WAN IP from the XR System Information page then access the Huawei and enter it into the DMZ function. Also on the Huawei set that same IP as static/reserved for the XR. Then see if the problem is resolved/happens less please
- conkerickJul 24, 2021Tutor
Ok, so...
Modem IP is 172.16.0.1
Router IP is 172.16.0.2 (reserved with a 30 days lease and DMZ enabled)
The router is configured: "Internet IP Address -> Use Static IP Address".
- Netduma-FraserJul 24, 2021NetDuma PartnerOkay great, let us know how you get on!
- conkerickJul 25, 2021Tutor
Hello, the daily reboot did not occur yesterday. However, the same DHCP issue occurred again.
This time it happened in a way that I had previously noticed.
In my country we suffer from electrical problems, voltage spikes and power outages.
The router and modem are connected to an UPS, which allows me to continue having Internet and WiFi.Today we suffered a power outage that lasted approximately 2 hours. As soon as the service was restored, I realized that no WiFi device could connect to the router. I unplugged the extender and the problem continued.
Only my phone and my wife's phone were still connected to the WiFi, as soon as I logged out and tried to connect, my phone was not getting ip address.
The only way to connect my phone was by putting a fixed ip, because with dhcp it does not work.
My PC which is wired, DHCP is working fine:
Microsoft Windows [Versión 10.0.19043.1110] (c) Microsoft Corporation. Todos los derechos reservados. C:\Users\xxx>ipconfig /release Configuración IP de Windows Adaptador de Ethernet Ethernet: Sufijo DNS específico para la conexión. . : Vínculo: dirección IPv6 local. . . : fe80::e032:ca72:87c9:9ab4%5 Puerta de enlace predeterminada . . . . . : C:\Users\xxx>ipconfig /renew Configuración IP de Windows Adaptador de Ethernet Ethernet: Sufijo DNS específico para la conexión. . : Vínculo: dirección IPv6 local. . . : fe80::e032:ca72:87c9:9ab4%5 Dirección IPv4. . . . . . . . . . . . . . : 192.168.8.3 Máscara de subred . . . . . . . . . . . . : 255.255.255.0 Puerta de enlace predeterminada . . . . . : 192.168.8.1 C:\Users\Erick Ospino>
It seems that when the electricity returns, the large number of devices trying to connect to the router, the DHCP collapses or blocks or believe that there is an attack?
I must clarify that the router never turned off during the power outage and I have not restarted it either, so I have still the issue. I have not wanted to reboot until find something that solve the issue.
Current Time: Sunday, Jul 25, 2021 15:26:48 [DumaOS] Marking device that is marked 192.168.8.36 14 35., Sunday, July 25, 2021 15:26:48 [DumaOS] DHCP lease change., Sunday, July 25, 2021 15:26:47 [DumaOS] DHCP new event., Sunday, July 25, 2021 15:26:47 [DHCP IP: 192.168.8.36] to MAC address d8:0d:17:20:69:1a, Sunday, July 25, 2021 15:26:47 [DumaOS] DHCP lease change., Sunday, July 25, 2021 15:26:46 [DumaOS] DHCP new event., Sunday, July 25, 2021 15:26:46 [DHCP IP: 192.168.8.37] to MAC address 68:ff:7b:e8:65:0c, Sunday, July 25, 2021 15:26:46 [DumaOS] DHCP lease change., Sunday, July 25, 2021 15:26:44 [DumaOS] DHCP new event., Sunday, July 25, 2021 15:26:44 [DHCP IP: 192.168.8.37] to MAC address 68:ff:7b:e8:65:0c, Sunday, July 25, 2021 15:26:44 [DumaOS] Marking device that is marked 192.168.8.40 13 35., Sunday, July 25, 2021 15:26:37 [DumaOS] DHCP lease change., Sunday, July 25, 2021 15:26:36 [DumaOS] DHCP new event., Sunday, July 25, 2021 15:26:36 [DHCP IP: 192.168.8.40] to MAC address 68:ff:7b:e8:5b:28, Sunday, July 25, 2021 15:26:36 [DumaOS] Marking device that is marked 192.168.8.36 14 35., Sunday, July 25, 2021 15:26:35 [DumaOS] DHCP lease change., Sunday, July 25, 2021 15:26:35 [DumaOS] DHCP new event., Sunday, July 25, 2021 15:26:35 [DHCP IP: 192.168.8.36] to MAC address d8:0d:17:20:69:1a, Sunday, July 25, 2021 15:26:35 [DumaOS] Marking device that is marked 192.168.8.33 25 35., Sunday, July 25, 2021 15:26:33 [DumaOS] DHCP lease change., Sunday, July 25, 2021 15:26:33 [DumaOS] DHCP new event., Sunday, July 25, 2021 15:26:33 [DHCP IP: 192.168.8.33] to MAC address 68:ff:7b:e8:7a:e8, Sunday, July 25, 2021 15:26:33 [DumaOS] Marking device that is marked 192.168.8.39 16 35., Sunday, July 25, 2021 15:26:31 [DumaOS] DHCP lease change., Sunday, July 25, 2021 15:26:31 [DumaOS] DHCP new event., Sunday, July 25, 2021 15:26:31 [DHCP IP: 192.168.8.39] to MAC address 98:da:c4:c8:24:18, Sunday, July 25, 2021 15:26:31 [DumaOS] Marking device that is marked 192.168.8.39 16 35., Sunday, July 25, 2021 15:26:30 [DumaOS] DHCP lease change., Sunday, July 25, 2021 15:26:29 [DumaOS] DHCP new event., Sunday, July 25, 2021 15:26:29 [DHCP IP: 192.168.8.39] to MAC address 98:da:c4:c8:24:18, Sunday, July 25, 2021 15:26:29 [admin login] from source 192.168.8.3, Sunday, July 25, 2021 15:26:27 [DumaOS] Marking device that is marked 192.168.8.36 14 35., Sunday, July 25, 2021 15:26:22 [DumaOS] DHCP lease change., Sunday, July 25, 2021 15:26:22 [DumaOS] DHCP new event., Sunday, July 25, 2021 15:26:22 [DHCP IP: 192.168.8.36] to MAC address d8:0d:17:20:69:1a, Sunday, July 25, 2021 15:26:22 [DumaOS] Marking device that is marked 192.168.8.33 25 35., Sunday, July 25, 2021 15:26:21 [DumaOS] DHCP lease change., Sunday, July 25, 2021 15:26:20 [DumaOS] DHCP new event., Sunday, July 25, 2021 15:26:20 [DHCP IP: 192.168.8.33] to MAC address 68:ff:7b:e8:7a:e8, Sunday, July 25, 2021 15:26:20 [admin login] from source 192.168.8.3, Sunday, July 25, 2021 15:26:19 [admin login] from source 192.168.8.3, Sunday, July 25, 2021 15:26:19 [admin login] from source 192.168.8.3, Sunday, July 25, 2021 15:26:19 [admin login] from source 192.168.8.3, Sunday, July 25, 2021 15:26:19 [admin login] from source 192.168.8.3, Sunday, July 25, 2021 15:26:19 [DumaOS] DHCP lease change., Sunday, July 25, 2021 15:26:19 [DumaOS] DHCP new event., Sunday, July 25, 2021 15:26:19 [DHCP IP: 192.168.8.37] to MAC address 68:ff:7b:e8:65:0c, Sunday, July 25, 2021 15:26:19 [DumaOS] Marking device that is marked 192.168.8.39 16 35., Sunday, July 25, 2021 15:26:05 [DumaOS] DHCP lease change., Sunday, July 25, 2021 15:26:05 [DumaOS] DHCP new event., Sunday, July 25, 2021 15:26:05 [DHCP IP: 192.168.8.39] to MAC address 98:da:c4:c8:24:18, Sunday, July 25, 2021 15:26:05 [DumaOS] Marking device that is marked 192.168.8.39 16 35., Sunday, July 25, 2021 15:26:04 [DumaOS] DHCP lease change., Sunday, July 25, 2021 15:26:04 [DumaOS] DHCP new event., Sunday, July 25, 2021 15:26:04 [DHCP IP: 192.168.8.39] to MAC address 98:da:c4:c8:24:18, Sunday, July 25, 2021 15:26:04 [DumaOS] Marking device that is marked 192.168.8.41 24 35., Sunday, July 25, 2021 15:25:54
- Netduma-FraserJul 25, 2021NetDuma PartnerThe only fix for this will be a software fix from the NG devs, while this is something they're working on I don't have a specific ETA on that but I'm hoping it will be relatively soon. Given it was caused by power fluctuations I think the only thing you can do is to reboot it
I "solved" the issue without rebooting:
- Disabled XR as a DHCP server.
- Installed DDWRT software in my R9000 (which was operating without problems until I decided to upgrade to XR).
- Configured the R9000 to work only as a DHCP server.
- Everything is working flawlessly. WITHOUT REBOOTING THE XR.
So... there is definitely a very serious issue with DHCP on the XR.
I think it is a lack of respect on the part of Netgear that they don't solved this problem yet. If you search on this forum or Google, you'll find people with same problem. It's a shame that the experience of the users and DumaOS, is affected by this HUGE issue.
DHCP functionality is basic on all routers. I describe this issue like: A glass of water that cannot hold water.
Hoping that Netgear fix this soon.
Thank you for all your support Liam and Fraser.
- Netduma-LiamJul 26, 2021NetDuma Partner
Well done for working out your own solution!
Thanks for your feedback too, we're aware that it's very disruptive for the users that experience it.
Keep an eye on the forum for when a fix is released, thanks again for your patience.
- Anas4567Aug 31, 2021Aspirant
Netduma-Liam wrote:Thanks for the detail, I'm unable to see the screenshots you've provided yet as they presumably need to be moderated.
Thanks for the detailed info.
