ryandhorn
Mar 21, 2018Guide
Yahoo and Instagram Won’t Load on iPhones and iPads
Just got the XR500 and my fiancée said Yahoo wouldn’t load on her iPhone 8. She said she couldn’t update her Instagram feed either. Used my iPhone 8 Plus and an iPad Mini and verified the same. The is...
- Mar 21, 2018
My geo filter is on no issue getting to yahoo at all on a lowly 55-16 Mbps. Have you tried just rebooting the router? It could be possibly a DNS issue but I can’t see how the router would block those two things. Is the router on the latest firmware? Have you tried a hard reset using the small recessed button on the back using a paper clip or similar object and setting up manually. Using cellular bypasses your ISP so also you could try using Google’s DNS Iinstead just to rule that out out. Google DNS are 8.8.8.8 and 8.8.4.4.
Killhippie
Mar 21, 2018Prodigy
Are you taking about yahoo mail via the web or an app? I dont use instagram but I can access Yahoo mail on my iPhone and all apps have updated fine.
