ryandhorn
Mar 20, 2018Guide
Yahoo and Instagram Won’t Load on iPhones and iPads
Just got the XR500 and my fiancée said Yahoo wouldn’t load on her iPhone 8. She said she couldn’t update her Instagram feed either. Used my iPhone 8 Plus and an iPad Mini and verified the same. The is...
- Mar 21, 2018
My geo filter is on no issue getting to yahoo at all on a lowly 55-16 Mbps. Have you tried just rebooting the router? It could be possibly a DNS issue but I can’t see how the router would block those two things. Is the router on the latest firmware? Have you tried a hard reset using the small recessed button on the back using a paper clip or similar object and setting up manually. Using cellular bypasses your ISP so also you could try using Google’s DNS Iinstead just to rule that out out. Google DNS are 8.8.8.8 and 8.8.4.4.
Netduma-Fraser
Mar 21, 2018NetDuma Partner
Can you confirm if other devices such as a laptop can load Yahoo fine?
Do the devices have both data & WiFi enabled at the same time - if so disable data, does it then load correctly?
Also WMM is enabled by default and I assume you're talking about the iPhones etc that are reaching above 300mbps, not wired devices which would be expected behaviour. Either way thats plenty of speed for simple web applications.
Are you using a VPN on the router or set up block sites/services?
ryandhorn
Mar 21, 2018Guide
Also: No VPN and I agree with you about simple web services, doesn’t make any sense. Why would devices getting 300/50 not be able to load a webpage or refresh Instagram?
