PieCaptain
Jun 25, 2019Guide
yealink W52P not working when connected to my xr500
Hi, I'm having trouble with my yealink W52P DECT phone when connected to my XR500. at the moment, i have it working by connecting it directly to my ISP modem (which is in router mode, I previously h...
- Jun 25, 2019Sorry to hear you're having this issue! I would also recommend disabling IGMP Proxying in WAN Settings. If that doesn't work disable QoS completely in Anti-Bufferbloat options, does that resolve it?
Netduma-Fraser
Jun 25, 2019NetDuma Partner
PieCaptain
Jun 25, 2019Guide
I did try disabling IGMP, but I have not tried disabling QOS. Will try that!
Thanks
Thanks
- PieCaptainJun 25, 2019Guide
Disabling QOS did the trick!
I even re-enabled SIP ALG and IGMP and the phone still registers.
do you know why it doesn't work with QOS?
Is it fixable?- Netduma-FraserJun 25, 2019NetDuma PartnerOkay that’s good news. Could you reenable QOS and then disable Traffic Prioritisation and see if it works then as that might be the part that’s affecting it.
- PieCaptainJun 28, 2019Guide
That also worked! Thanks!
