PieCaptain
Jun 25, 2019Guide
yealink W52P not working when connected to my xr500
Hi, I'm having trouble with my yealink W52P DECT phone when connected to my XR500. at the moment, i have it working by connecting it directly to my ISP modem (which is in router mode, I previously h...
- Jun 25, 2019Sorry to hear you're having this issue! I would also recommend disabling IGMP Proxying in WAN Settings. If that doesn't work disable QoS completely in Anti-Bufferbloat options, does that resolve it?
Netduma-Fraser
Jun 25, 2019NetDuma Partner
Okay that’s good news. Could you reenable QOS and then disable Traffic Prioritisation and see if it works then as that might be the part that’s affecting it.
PieCaptain
Jun 28, 2019Guide
That also worked! Thanks!
- Netduma-FraserJun 29, 2019NetDuma PartnerOkay great to hear that, so instead keep DumaOS Classified Games disabled and add any game devices with the console service and you can still benefit from the feature.
