Christiaan11
Nov 01, 2022Apprentice
Yesterday ran into issues again
Do you have more information about what is included in this release? As this is taking so long, my concern is that the backlog of fixes/improvements i growing in parallel. Do we have to wait another ...
Nov 01, 2022Guru - Experienced User
What was the reason for the reboot?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How do you have the LAN DHCP features and Wireless settings configured?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- Christiaan11Nov 01, 2022Apprentice
Thanks for your reply. I don't have any issues with the WiFi. It's just the stability overall and fact that the router still has some bugs and the interface is so slow to work with. The topic I was supposed to reply to is about the lack of VPN.
Overall it just doesn't feel as a high tier router.
- Netduma-FraserNov 01, 2022NetDuma PartnerI think we're feeling pretty confident that this next update will be a good one - we're putting a lot of time into getting it right.
- FURRYe38Nov 01, 2022Guru - Experienced User
Maybe if you gave some feedback to the questions presented we can help you with your router stability issues. I've not seen any instability issues with my XR1000 since putting it online back in Oct. Running well. Should be going on 10 days up time since last reboot I did.
Though I agree, logging into the web page is slow however it does eventually appear.
Netduma-Fraser thanks again for the reply and the work everyone is putting in this update. Looking forward to it 🙂
Most of the issues that I have described below. My network is optimized by a professional about two months ago. So all cables Cat6 and most devices are connected wired.
- Biggest issue so far: factory reset after reboot yesterday.
- VPN: I was expecting VPN on this router as other nighthawks seem to have this. But, unfortunately it's not there. However, I understand that this is coming in the new update.
- Geo Filter:
- at one point it stopped working. Following instructions on the other thread fixed it for me (removing gaming device and resyncing cloud)
- Still I'm not sure if it's always on. Sometimes I see servers popping up on the interface when gaming, other times nothing happens.
- Ping in the game (COD Warzone) is always higher then what router is telling me)
- When doing connection benchmark, most of the time speed and ping is A+. However, under load it's always under performing (D). It's unclear how I can improve this and what is causing it).
- Since I have this router it feels to me that often something is going wrong with IP reservations. Devices are acting funky after a reboot of the device (e.g. raspberry PI, Musiccast speakers). Some devices have multiple IPs connected to them, in some cases looks like double assigned IPs.
- Reason for reboot this week: NAT was moderate again on PS5 while I didn't make any changes. Now (after the reset) UPnP seems to be doing it's job again and NAT is OPEN again.
- Very slow app: checking something in the app is very slow and painful.
