Christiaan11
Nov 01, 2022Apprentice
Yesterday ran into issues again
Do you have more information about what is included in this release? As this is taking so long, my concern is that the backlog of fixes/improvements i growing in parallel. Do we have to wait another ...
Nov 01, 2022Guru - Experienced User
What was the reason for the reboot?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How do you have the LAN DHCP features and Wireless settings configured?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Christiaan11
Thanks for your reply. I don't have any issues with the WiFi. It's just the stability overall and fact that the router still has some bugs and the interface is so slow to work with. The topic I was supposed to reply to is about the lack of VPN.
Overall it just doesn't feel as a high tier router.
