ouq77
Nov 29, 2019Tutor
2FA - Change Primary Trusted Device
I have changed to a new mobile device and am unable to figure out how to change the primary trusted device from my old phone to the new one (or remove other devices from the list). In the Orbi An...
- Dec 11, 2019
Go to Netgear.com. Login into your MyNetgear account. Go to Manage Profile. Then Login Settings. Two Step Verification. Add your new SMS Text number. Then you delete old and make your new Text primary.
TongPoJones
Dec 11, 2019Initiate
- ouq77Dec 11, 2019TutorThanks so much! Hopefully this will come to the app at some point.
- esblofeldJan 07, 2020Initiate
There's no option there to change the Primary device. You can delete the Primary and obviously it will no longer be the Primary, but then you have to delete the app, reinstall, reconfigure and reverify it.
- AdewaleApr 21, 2020Luminaryi follow the steps and i don't see 2FA in my profile...whats the way out?
- mgibson323May 13, 2020Initiate
TongPoJones wrote:Go to Netgear.com. Login into your MyNetgear account. Go to Manage Profile. Then Login Settings. Two Step Verification. Add your new SMS Text number. Then you delete old and make your new Text primary.
Hi,
This solution does not work for me - there is no "Two Step Verification" item listed in the "Manage Profile" section for my account on the website. Please see the attached screenshot.
Also the mobile app (I have iOS) says all trusted devices will be deleted if I disable 2FA, but when I do disable 2FA, the trusted device I previously added (my iPad) remains. I cannot see any way to add any new ones, nor can I delete the existing one. This seems quite buggy.
So, I'd like to be able to add my iPhone as a trusted device, replacing the iPad, and then remove the iPad. How can I do so?
Thank you.
