ouq77's avatar
ouq77
Tutor
Nov 29, 2019
2FA - Change Primary Trusted Device
I have changed to a new mobile device and am unable to figure out how to change the primary trusted device from my old phone to the new one (or remove other devices from the list).   In the Orbi An...
  • TongPoJones's avatar
    Dec 11, 2019
    Go to Netgear.com.  Login into your MyNetgear account. Go to Manage Profile. Then Login Settings.  Two Step Verification.  Add your new SMS Text number.  Then you delete old and make your new Text primary.
