ouq77
Nov 29, 2019Tutor
2FA - Change Primary Trusted Device
I have changed to a new mobile device and am unable to figure out how to change the primary trusted device from my old phone to the new one (or remove other devices from the list). In the Orbi An...
- Dec 11, 2019
Go to Netgear.com. Login into your MyNetgear account. Go to Manage Profile. Then Login Settings. Two Step Verification. Add your new SMS Text number. Then you delete old and make your new Text primary.
TongPoJones
Dec 11, 2019Initiate
esblofeld
Jan 07, 2020Initiate
There's no option there to change the Primary device. You can delete the Primary and obviously it will no longer be the Primary, but then you have to delete the app, reinstall, reconfigure and reverify it.
