Gachamp2
Jun 23, 2023Follower
Access Anywhere - remote
I'm not able to access the router remotely. Access Anywhere is turned on, but it won't connect to the router when I open the app off the wifi network. I have to be on the same network wifi to connect...
michaelkenward
Jun 24, 2023Guru - Experienced User
What are you trying to do?
Netgear has been playing around with remote access and has killed some features on security grounds.
Remote Management is now Anywhere Access in the Nighthawk and Orbi apps | Answer | NETGEAR Support
Why is the Remote Management feature being removed from NETGEAR routers? | Answer | NETGEAR Support
