thedak
Jul 11, 2020Apprentice
Android/iOS App won't looses connection to RBR850 (RBK853) starting with Firmware 3.2.15.25
Hi, is anyone else seeing this problem? Starting with RBR/RBS 850 firmware upgrade to 3.2.15.25 both Android and iOS apps (adroid latest version 2.5.4.1036) loose connection to my RBR850. After...
Jul 12, 2020Guru - Experienced User
What is the Mfr and model# of the main host router in front of the RBR850 in AP mode?
I know last time I had mine in AP mode connected to my CAX80 in router mode, the nighthawk app was not able to connect to the CAX thru the Orbi in AP mode, I was able to in v15.25 If I remember rightn
I updated mine to v32 today and both iphone and adroid app sees the RBR, however mines in router mode.:smileyvery-happy:
I'll keep checking mine this weekend.
thedak
Jul 12, 2020Apprentice
Main host router is Sophos XG 18. Been working perfectly since the day I installed the rbk853 and have always used in AP mode. Worked great on my RBK53 as well (AP) for years. Only thing that changed was latest FW. Thanks for checking.
- FURRYe38Jul 13, 2020Guru - Experienced User
You might change the RBR to router mode temporarily to see if this changing anything...
I'll try mine in AP mode this week and check as well.
