thedak
Jul 11, 2020Apprentice
Android/iOS App won't looses connection to RBR850 (RBK853) starting with Firmware 3.2.15.25
Hi, is anyone else seeing this problem? Starting with RBR/RBS 850 firmware upgrade to 3.2.15.25 both Android and iOS apps (adroid latest version 2.5.4.1036) loose connection to my RBR850. After...
thedak
Jul 12, 2020Apprentice
Main host router is Sophos XG 18. Been working perfectly since the day I installed the rbk853 and have always used in AP mode. Worked great on my RBK53 as well (AP) for years. Only thing that changed was latest FW. Thanks for checking.
Jul 13, 2020Guru - Experienced User
You might change the RBR to router mode temporarily to see if this changing anything...
I'll try mine in AP mode this week and check as well.
