thedak
Jul 11, 2020Apprentice
Android/iOS App won't looses connection to RBR850 (RBK853) starting with Firmware 3.2.15.25
Hi, is anyone else seeing this problem? Starting with RBR/RBS 850 firmware upgrade to 3.2.15.25 both Android and iOS apps (adroid latest version 2.5.4.1036) loose connection to my RBR850. After...
Chillbill90
Aug 04, 2020Aspirant
I have the exact same issue, exactly as you describe. After about six hours, I can only connect from the IOS app via Anywhere Access. If I reboot the Orbi, the same cycle starts over. I can connect for about 6 hours, and then the app will no longer connect.
