thedak
Jul 11, 2020Apprentice
Android/iOS App won't looses connection to RBR850 (RBK853) starting with Firmware 3.2.15.25
Hi, is anyone else seeing this problem? Starting with RBR/RBS 850 firmware upgrade to 3.2.15.25 both Android and iOS apps (adroid latest version 2.5.4.1036) loose connection to my RBR850. After...
Chillbill90
Aug 04, 2020Aspirant
I went through all the same steps -- factory reset, reverting to last FW, resetting router, etc. The same thing contineus to happen. After about 6 hours, the IOS app can no longer detect the Orbi and I have to connect via Anywhere Access.
thedak
Aug 04, 2020Apprentice
I upgraded my iOS and Android Apps and the problems seems to have disappeared. What Android App version are you on?
- Chillbill90Aug 04, 2020Aspirant
I am using the up-to-date version of the IOS app. The problem remains. Perhaps an app update for IOS is coming soon if the Android app has been recently updated.
- Christian_RAug 10, 2020NETGEAR Employee Retired
Hi Chillbill90,
May you confirm what Orbi app version you currently have installed?
Thanks,Christian
- Chillbill90Aug 10, 2020Aspirant2.6.0.12
