JGNY123
May 11, 2022Aspirant
Any success of connection after factory reset?
Any success of connection after factory reset? I am having the same problem with orbi750. WI-FI is working fine but app doesn’t find the router. Installed new apps on 3 different iPhones but none is...
May 12, 2022Guru - Experienced User
Factory reset and setup from scratch using a wired PC and web browser at HTTP 192.168.1.1. Don't use Orbi app.
