RockTheGlobe
Mar 13, 2023Apprentice
Any way to bypass Armor signup when logging in?
While I have the Orbi app downloaded to my iPad and iPhone, I've avoided using it for the past several months because every time I open it, I can't get past the splash screen where it asks me to agre...
Mar 13, 2023Guru - Experienced User
No there isn't without activating that I know of.
Annoys the crap out of me too.
there should be a check mark to "never ask me again" type thing
- FURRYe38Mar 13, 2023Guru - Experienced User
I wish there was a (X) button.
I guess activate it then you can disable it under Settings/Security with in the NH app.
