VerneArase
Sep 18, 2020Apprentice
Anyone know how to get speed test working on RBR850?
Anyone know how to get the speed test working on the RBR850? Every time I try to use it it just hangs. Is there some trick (like putting netgear.com or ookla.com in the domain search path)? ...
Sep 18, 2020Guru - Experienced User
- VerneAraseSep 28, 2020Apprentice
Well then, does anyone know what domain name the QoS speed test is trying to hit?
It would make it a lot easier to debug the situation if I at least knew where the QoS speed test was trying to go.
