LLJ
Jul 13, 2023Star
Anywhere Access CBR40
I have anywhere accès turned on but when I’m away from home I keep getting a “offline” response. How does this work? Do I need to do something else? Totally lost!
michaelkenward
Jul 13, 2023Guru - Experienced User
To get remote access to your router you need to set up Anywhere Access with a MyNetgear account.
How do I enable or disable Anywhere Access on my NETGEAR or Orbi router? | Answer | NETGEAR Support
- LLJJul 21, 2023StarI have it setup but still no joy
- michaelkenwardJul 21, 2023Guru - Experienced User
With so little detail about what you are doing, it is hard to add anything.
Maybe someone on the section for your hardware can help:
Orbi with Built-in Cable Modem Systems - NETGEAR Communities
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.- LLJJul 21, 2023StarFirmware version V2.5.0.28
Anywhere access indicates it is on. I’m away from home and trying to connect to my CBR40 back at home. When I open the Orbi app it immediately tries to connect to my system. It does not connect and it tells me “unable to connect to router”. I thought anywhere access would let me connect to my system so I’m at a loss as to what to do so I can connect.
I appreciate any help anyone can provide. Thx…
