arees0921
Feb 18, 2023Tutor
Anywhere Access on RBR850 running firmware v4.6.14.3
After the latest firmware update I can no longer remotely access my router using the Orbi iOS app. I receive a message saying that Anywhere Access has to be turned on on the router however I am unab...
CrimpOn
Feb 18, 2023Guru - Experienced User
arees0921 wrote:
Router documentation has no references to Anywhere Access.
True, Anywhere Access is part of the Orbi 'app' and is not part of the web interface at all.
When connected locally to the router (on the Orbi LAN), open the Orbi app.
Then, select the menu in the upper left part of the app screen.
Select "Settings"
Then select Anywhere Access
arees0921
Feb 19, 2023Tutor
Thanks and I am aware of the mobile app setting. It’s on and been on. I was traveling this week and received a message from the router over the Orbi mobile app but when I tried to access the router using it, I received a message saying that I needed to turn something on when connected to the same WiFi as my router. Will need to reproduce the message and get back.
