aaronmcd1214
Sep 12, 2020Tutor
Anywhere Access
I've been trying to enable Anywhere Access on my router from the app but the toggle doesn't stay on. Any help would be appreciated.
Mstrbig
Sep 12, 2020Master
aaronmcd1214 wrote:I've been trying to enable Anywhere Access on my router from the app but the toggle doesn't stay on. Any help would be appreciated.
I mostly use the app for all installs, since I'm in the field and it is much easier.
It should be a simple configuration. Try uninstalling the app and reinstalling it first then follow this:
To enable or disable Anywhere Access on your Orbi router using the Orbi app:
Connect your mobile device to your Orbi WiFi network.
Launch the Orbi app.
Tap the Menu icon in the upper-left corner
Tap SETTINGS>Anywhere Access.
The Anywhere Access page displays.
Toggle the Enable Anywhere Access slider.
Toggling the slider to the right turns the slider green and enables Access Anywhere.
Toggling the slider to the left turns the slider white and disables Access Anywhere.
To manage your Orbi device when not connected to your Orbi WiFi network, launch the Orbi app and tap CONNECT VIA ANYWHERE ACCESS.
TH72
Oct 14, 2020Initiate
The toggle doesnt stay enabled.... it says its enabled, but the slider goes back to disabled... pretty easy to use a slider like on any other app. but this one self disables... anyone got a fix to this? not steps on how to use a slider
