aaronmcd1214
Sep 12, 2020Tutor
Anywhere Access
I've been trying to enable Anywhere Access on my router from the app but the toggle doesn't stay on. Any help would be appreciated.
Christian_R
Dec 08, 2020NETGEAR Employee Retired
Hello ILB,
You will need to email our Customer Care at [email protected] and provide your email address and router serial number.
Christian
larryindublin
Dec 19, 2020Luminary
I found that I could not turn Anywhere Access on from my Android phone (the toggle would turn itself off after I would turn it on) BUT last night tried from an Ipad and it worked fine and is now on (I tested on cellular and could connect to my router).
- KMDonlonDec 20, 2020VirtuosoI found that on Android is you are using a filtered Private DNS and do not have location enabled it will do exactly what you are experiencing.
