aaronmcd1214
Sep 12, 2020Tutor
Anywhere Access
I've been trying to enable Anywhere Access on my router from the app but the toggle doesn't stay on. Any help would be appreciated.
larryindublin
Dec 19, 2020Luminary
I found that I could not turn Anywhere Access on from my Android phone (the toggle would turn itself off after I would turn it on) BUT last night tried from an Ipad and it worked fine and is now on (I tested on cellular and could connect to my router).
KMDonlon
Dec 20, 2020Virtuoso
I found that on Android is you are using a filtered Private DNS and do not have location enabled it will do exactly what you are experiencing.
