StephenCn6812t
Mar 05, 2024Aspirant
anywhere access
Hello, all. I have been using this system successfully with anywhere access for a few years now, just moved into a new house. In the course of setting up backhaul over MOCA, I had to factory res...
CrimpOn
Mar 05, 2024Guru - Experienced User
When you open the menu (upper left of the screen), the top entry shows the model number of the router.
This says, "Connected Locally", correct?
Is there an arrow that opens to show other options?
StephenCn6812t
Hmmm. After two days, it is now oddly back to working. Thanks for trying to help, Not sure why it suddenly accessed.
- CrimpOnMar 05, 2024Guru - Experienced User
One of those "Mysteries of Life". Netgear has a Status Page that supposedly shows which systems are working and which are having problems:
https://status.netgear.com/orbi
It appears that Remote Access status was last updated on Feb 27.
