biggator
Oct 14, 2020Tutor
App and web interface - different and incorrect information
Have had an existing Orbi system for about 15 months. One RBR50/one RBS50. I just added a second RBS50 to my system, one is wireless backhaul and the other (after a lot of frustration) is wired....
LuizAlmeida
Nov 03, 2020Star
Hi,
I just figure out I have the same problem. :(
I don't know if the problem is the App or in the orbi firmware.
I have 1 RBR50 (firmware v2.5.2.4), 2 RBS50 (firmware v2.5.2.4 - backhaul by wire) and 1 RBS50Y (firmware v2.3.5.32).
The App show me the RBR50 status (green) but all the satellites seem to be offline (which is not true)
It's very annoying.
- LuizAlmeidaNov 10, 2020Star
Hi biggator,
I just saw there is a new firmware available (2.6.1.40 - I'm outside from USA).
Take a look: https://www.netgear.com/support/product/RBR50#download
I'll try next weekend.
Luiz Almeida
- biggatorNov 10, 2020Tutor
Just checked - not showing up for me yet.
Hi,
I couldn't wait for the weekend :smileyhappy:
I updated the my RBR50 and two RBS50. I didn't update the RBS50Y.
I also installed my Orbi App from the scratch.
Unfortunately, the result was the same.
The Orbi App shows wrong information about the satellites.
The web console shows satellites wrong versions.When Netgear is going to fix that?
Luiz Almeida
