walshie
Jun 25, 2020Follower
Armor activation
Hi - I have just installed RBR20 with two satellites. In the Orbi App I click on Security to activate...I get a window asking to activate trial, and then I get Error - Failed to subscribe. How do ins...
grimachek
Aug 02, 2020Aspirant
I'm having the same problem. When I attempt to activate Armor it times out and reads; "Failed to Subscribe"
- FURRYe38Aug 02, 2020Guru - Experienced User
There is a dedicated forum for Armor as well for future reference:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.
grimachek wrote:I'm having the same problem. When I attempt to activate Armor it times out and reads; "Failed to Subscribe"
- Christian_RAug 05, 2020NETGEAR Employee Retired
Hello grimachek,
May you reinstall the Orbi app and reboot your router.
Christian
- grimachekAug 06, 2020Aspirant
I did both, and registered product. Still not working
- Christian_RAug 12, 2020NETGEAR Employee Retired
grimachek,
May you send me a private message with your email address and serial number.
Thanks,Christian
