BDGAZ's avatar
BDGAZ
Follower
Oct 12, 2020
Attached devices not saving when updated (ORBI RBR850)
Greetings -
I realize this topic is rather old and has still not been rectified by Netgear - however I just wanted to submit
that it is still a problem with the ORBI RBR850. Attached device edits do not save (persist). I have tried on
the ORBI app and the router management web page. To no avail on either. On the ORBI app I am able to edit
both the icon and description. It saves, and then reverts back to the default after a few moments. On the router
management interface, I am able to change the device type but am unable to change the icon. I save the updated
device record and then it simply (the type) reverts back to default also.
This is extremely dissapointing Netgear. I also want to note that when beginning the composition of this post, after
the subject line the model specification is recommended. I was further dissapointed to see that the RBR8550 was not
even a valid choice! Come on Netgear... Surely you can do better than this!
ORBI RBR850
Firmware Version
V3.2.16.6_1.4.4
1 Reply
  • Same issue here & it was also talked about in the Orbi AX forum and nothing from any of the moderators as far as a fix. There are lots of app and firmware bugs ATM that are simply not getting addressed in a timely fashion. That is if they are even addressing them.
