hyperman27
Jan 12, 2024Aspirant
August device in device manager
I have an unconnected device in my device manager that is a long alphanumeric string and below that it says August. When I go to the august website it says they make smart locks. We have never had ...
hyperman27
Thank you. So to turn it off I just disable the private network switch on the network?
CrimpOn
Jan 12, 2024Guru - Experienced User
Delete the device from the app table of connected devices.
Turn off the feature on any smart phones, tablets, or laptops.
- hyperman27Jan 12, 2024Aspirant
Its disconnected and I will delete it. When you say turn off the feature do you mean the private wifi address button on the blue i for the wifi its connected to on each device? Or is there something else in the settings we have to do?
