RafS
Mar 04, 2020Apprentice
AX6000 Device List not sorted by band, only listed by wired or wireless.
Not sure if this is by design of if I have an issue going on. When I first started setting up my AX6000, and started adding devices, the devices were sorted by either WIRED, 2.4GHZ or 5GHZ. After everything was added, the list completely changes and all devices are now listed as either WIRED or WIRELESS (I have checked the filter and it is set correctly)Initial SetupAfter all devices addedNetwork Map RouterNetwork Map satellite. I have reset the system 3 times now and started from scratch each time only to end up with the same result each time. Also, when going into the Network Map and selecting either the RBR850 or the satellite, neither one shows any devices being attached to them, even though everything is working fine. My SSID is one word, there are no special characters in any of my device names, I know I have some devices that only work on 2.4GHZ so I should be showing devices in all fields, WIRED, 2.4 and 5 like it shows in one of the pictures before i finished adding the rest of my devices. I attached pictures to help explain.
1 Reply
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-appThank you.
