ddustin
Oct 09, 2022Guide
BR850 Orbi, anywhere access no longer working
Hello, First post here, experienced user. Anywhere access used to work, but since updating the firmware of the RBR850 and the Satellite (RBS850), anywhere access refuses to work. While home, the ap...
CrimpOn
Oct 09, 2022Guru - Experienced User
ddustin wrote:
when I try to enable remote access on the router directly, there is an instruction to "To use Access Control, please use the Orbi App."
Access Control on the Advanced Tab is a method to control which devices are allowed to access the LAN, defined by their hardware MAC address. It has nothing to do with accessing the router remotely (from the internet).
ddustin wrote:
Using an iOS device running 15.6.1, but have also tried it on an Android phone (same results).
Was the Android phone connected on the local network when you attempted to enable Access Anywhere?
There have been a number of posts recently from users frustrated with the most recent Orbi 'app' for Apple devices. So far, my Android devices have not been affected.
It does not address the specific question about the app, but it appears you realize that having OpenVPN enabled on the router means that you can access the Orbi web browser administration remotely. Personally, I find the browser administration to be far superior to the 'app'.
ddustin
Oct 09, 2022Guide
Hey CrimpOn, thanks for the response..
To answer your questions:
1. The Android device was on the same network and local to the router.
2. I am not using Open VPN, instead, I'm using "ZeroTier" for a variety of reasons (it works very well). ZT only allows me to connect to a computer on my network via remote desktop, and then I connect to the router directly from that device. ZT is also installed on my phone as a VPN which I use to access my surveillance system remotely.
I like the Orbi for performance, but the quirks with updates etc are a real pain đ
- CrimpOnOct 09, 2022Guru - Experienced User
Zero Tier. Wow. The forum introduces me to amazing things!
On the Android phone, does the menu option for Anywhere Access appear at all on the Settings Menu when the phone is connected to the network? (For me, it is the bottom menu item under Settings.)
- ddustinOct 09, 2022Guide
CrimpOn,
Yes the enable AccessAnywhere slider is visible at the top of the screen. Selecting it results in the failure. It is also visible in the settings menu.
Regarding ZeroTier... I'm a huge fan. the UI for setup is fairly straight forward.. It doesn't run on our Orbi's though, but it does allow access via the web UI of a network connected computer (remote desktop or other remote software).
