qqjmj
Feb 26, 2025Tutor
Can’t connect to Orbi RBK753P
Issue connecting with ORBI15 and WiFi Not Found. I’ve tried different solutions but it always says WiFi not found and ensure local network is enabled even though it is already enabled.
qqjmj
Feb 27, 2025Tutor
Yes, I’ve done a factory reset reinstalled it multiple times, but all it gives me on the Orbi App is ORBI Not Found. And it’s a new system.
CrimpOn
Feb 27, 2025Guru - Experienced User
When the router is Factory Reset, your phone should detect a WiFi system with the name printed on the label (bottom of the router). That shows up, correct?
And the password for this WiFi connection should be what is printed on the label.
Are you able to connect the phone to this WiFi signal?
