qqjmj
Feb 26, 2025Tutor
Can’t connect to Orbi RBK753P
Issue connecting with ORBI15 and WiFi Not Found. I’ve tried different solutions but it always says WiFi not found and ensure local network is enabled even though it is already enabled.
qqjmj
Feb 27, 2025Tutor
Yes, I’ve done a factory reset reinstalled it multiple times, but all it gives me on the Orbi App is ORBI Not Found. And it’s a new system.
Feb 27, 2025Guru - Experienced User
have you tried setting it up through the browser and not the app? I'm not a huge fan of the app and there's been a bunch of posts lately with issues on the app.
- plemansFeb 27, 2025Guru - Experienced User
theres a guide here on using the browser:
https://kb.netgear.com/31017/How-do-I-set-up-my-Orbi-WiFi-System
- qqjmjFeb 27, 2025TutorI tried doing it through the browser, but it tells me “The Site Can’t Be Reached.” I can search things up on Chrome and it’ll load. But when I try orbilogin.net or the IP Address, it just says the site can’t be reached and refused to connect. (And I’m connected to the ORBI network.)
what modem/gateway is it connected to? It might be on 192.168.0.1 or 10.0.0.1 if you're in a double nat
