qqjmj
Feb 26, 2025Tutor
Can’t connect to Orbi RBK753P
Issue connecting with ORBI15 and WiFi Not Found. I’ve tried different solutions but it always says WiFi not found and ensure local network is enabled even though it is already enabled.
qqjmj
Feb 27, 2025Tutor
I tried doing it through the browser, but it tells me “The Site Can’t Be Reached.” I can search things up on Chrome and it’ll load. But when I try orbilogin.net or the IP Address, it just says the site can’t be reached and refused to connect. (And I’m connected to the ORBI network.)
Feb 27, 2025Guru - Experienced User
what modem/gateway is it connected to? It might be on 192.168.0.1 or 10.0.0.1 if you're in a double nat
- qqjmjFeb 27, 2025TutorI’m pretty sure it’s connected to 10.0.0.1
- FURRYe38Mar 10, 2025Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
