usafstud
Nov 23, 2020Tutor
Can’t show devices connected
I also can't see a list of devices connected to my system on my app. It just says no devices connected to individual satellites/route and an error code of "Could not reach server. Try again later (cod...
Christian_R
Dec 01, 2020NETGEAR Employee Retired
Hi usafstud,
May you reinstall the Orbi app and check to see if your Orbi devices are due for a firmware update.
Christian
ricktra
Dec 03, 2020Aspirant
I just used tech support to update router firmware to V2.7.1.60. Web login shows all devices but app is "unable" and indicates Sorry, the action was failed" with a code : CDIL-API-FAIL
my app version is 2.7.0.28
I restarted iOS then launched app...no success
I deleted app on iOS and reinstalled as new set up...no success
Please advise
- ricktraDec 03, 2020Aspirant
still have problem as described above
- usafstudDec 03, 2020Tutor
ricktra wrote:I just used tech support to update router firmware to V2.7.1.60. Web login shows all devices but app is "unable" and indicates Sorry, the action was failed" with a code : CDIL-API-FAIL
Please advise
I restarted/deleted as you did and still have exact same issue as you. Web browser shows items connected, but "unable" on the app.
You and I can't be the only ones.
I am still under warranty and opened a case on this. I will ask if they can post the resolution here once they solve the issue.
