Thumbad
Jul 07, 2023Aspirant
Can not disable Guest Wi Fi on RBR50.
I have RBR50 with 2 satellites. The Firmware Version: V2.7.4.24 and Orbi App version: 2.27.1.79. I wanted to disable Guest Wi-Fi. When I move radio from enabled to disable and try to save, it gives ...
Jul 07, 2023Guru - Experienced User
Does disabling it on the RBRs web page with a browser work?
Might review more recent FW updates:
Submit a bug if you can't get Orbi app to work for this:
