SteerPaul
Sep 25, 2023Aspirant
Can not receive push notifications Orbi RBR50
When I attempt to log into the Orbi app it says it doesn't recognize the device. The push notification to the device doesn't work and the alternative e-mail verification method points to an e-mail tha...
Sep 28, 2023Guru - Experienced User
Uninstall the app from your devices then re-install it. It should have you log in to your NG account using the new email address configured there...
- SteerPaulSep 28, 2023AspirantThank you for the reply, I installed the app from my phone and reinstalled. I can log in to NG using the new email address but when the push notification fails it says try alternate method and it has my old email address listed as the email to send the alternate method to. It won't let me go in and change that email on the app because it can't authenticate my device. The desktop version of the site doesn't even have my orbi app on it so I can't use my desktop
- FURRYe38Sep 28, 2023Guru - Experienced User
You'll need to contact NG support and have them help you get that corrected:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
