VB_RC
Feb 26, 2021Aspirant
can not renew license
can not renew license in the Orbi app on my smart phone. There is a banner - says license expires 2021-3-10. Save 35% now. Nothing happens when I try to slide the banner. I read in the community n...
VB_RC
Mar 03, 2021Aspirant
Christian: HI and thanks for your email.
I want to clarify a few things.
(1) Do I need to power cycle only my Orbi router or the Orbi network (my cable provided modem and my Orbi router)? I thought I should do both.
(2) After I turn off/unplug the Orbi router, I need to unplug the 2 wall plug satellites - correct?
(3) A netgear article says I need to turn off or shut down all of the devices that are connected to the router's network. I assume this would mean my TVs and iphones only. There are several apps on our iphones that connect to WiFI so I don't need to do anything with them (e.g. our kitchen stove and thermostats are connected thru WIFI). Is this correct?
Thanks so much for your assistance.
VB_RC
Mar 04, 2021Aspirant
Christain: HI I realize you may be very busy but I would greatly appreciate a response to my questions on power cycling.
Thanks and have a great day.
- Christian_RMar 05, 2021NETGEAR Employee Retired
Hello VB_RC,
I would recommend power cycling the Orbi router only and reinstalling the Orbi app. If you can also provide a screenshot of the banner in the Orbi app that would be awesome.
Thanks,Christian
- VB_RCMar 06, 2021Aspirant
Hi Christian:
ok -- I will try your recommendation later today.
I have attached a document which shows the banner in the Orbi app of the 35% off.
- VB_RCMar 07, 2021Aspirant
Christian: Hi and good day. Last night and again this morning I power cycled the router/satelites only and reinstalled the ORBI app. When I go to the banner on the Orbi app for renewal at a 35% discount, nothing happens -- same as before.
I dont' know if this matters -- but I bought the Orbi WiFi system from Best Buy with total tech support for the first year. I stopped by Best Buy yesterday -- the Geek Squad rep said that I would have to wait until the subscription expires -- March 10 -- and then I can renew then. Not sure what, if any, discount will apply.
I also have Bitdender installed. Not sure if or how this matters for my Orbi renewal.
Any future suggestions?
