majkinetor
Nov 28, 2022Aspirant
Can't login with correct credentials
2 times in last year it happened that I can't login with correct credentials. Orbi RBK353 and 2 RBS350. There is not "Invalid user/pass" but page simply refreshes. Later I can login (for instance...
Nov 28, 2022Guru - Experienced User
What mobile platform are you using?
What is the app version your using?
Try removing the app and re-installing it.
If on Apple, be sure to disable WiFi Private IP address as well:
majkinetor
I am using Chrome browser on Windows 10.
- FURRYe38Nov 28, 2022Guru - Experienced User
And does using the password recovery option help get you back in?
Be sure to clear out ALL browser caches and clear any saved password configurations within the browser as well.
- majkinetorNov 28, 2022Aspirant
There is no password recovery on that page
FURRYe38 wrote:And does using the password recovery option help get you back in?
I did.
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
Does this happen with MS Edge or Firefox browsers?
