Royalh13
Oct 28, 2022Star
Can't logon to Orbi - "Logon timed out, please try again" - FIXED!
It is ridiculous that Netgear's Orbi app STILL has this problem after more than 2 YEARS!
https://community.netgear.com/t5/Orbi-App/Orbi-App-Android-phone-quot-login-timed-out-please-try-again/m-p...
enhompe
Oct 29, 2022Tutor
I'm having the same issue today. Help!
- KnotreadyOct 29, 2022TutorUse an iphone instead of Android to turn on anywhere access. Reinstall the app on Android and once you open the app, hurry and click anywhere access when it pops up
- KapciuchOct 29, 2022InitiateDon't have iPhone and never will...
- jtcommunityOct 30, 2022Star
Did that... well, using an iPad. Didn't even have to hurry to get to "anywhere access" because the Android app automatically chose this. My problem with the workaround is that I try to avoid "anywhere access" because I consider it less safe. Netgear should really do something about this issue.
- cghermanOct 30, 2022Tutor100% agree on Anywhere Access, it's a security concern. At some point I believe I turned it off, or it's broken, who knows. Hopefully the bug is fixed soon.
- enhompeOct 30, 2022TutorI did so with my wife's iPhone. Anywhere access is in fact already on. But my Android app isn't showing the option you described as appearing on startup. Someone else suggested using an older Android phone. I'll try that next.
- cghermanOct 30, 2022TutorIf Anywhere Access doesn't show up as an option on Android, it seems that you can delete the app data and the option will appear (briefly).
