Royalh13
Oct 28, 2022Star
Can't logon to Orbi - "Logon timed out, please try again" - FIXED!
It is ridiculous that Netgear's Orbi app STILL has this problem after more than 2 YEARS!
https://community.netgear.com/t5/Orbi-App/Orbi-App-Android-phone-quot-login-timed-out-please-try-again/m-p...
Knotready
Oct 29, 2022Tutor
Use an iphone instead of Android to turn on anywhere access. Reinstall the app on Android and once you open the app, hurry and click anywhere access when it pops up
jtcommunity
Oct 30, 2022Star
Did that... well, using an iPad. Didn't even have to hurry to get to "anywhere access" because the Android app automatically chose this. My problem with the workaround is that I try to avoid "anywhere access" because I consider it less safe. Netgear should really do something about this issue.
- cghermanOct 30, 2022Tutor100% agree on Anywhere Access, it's a security concern. At some point I believe I turned it off, or it's broken, who knows. Hopefully the bug is fixed soon.
