Royalh13
Oct 28, 2022Star
Can't logon to Orbi - "Logon timed out, please try again" - FIXED!
It is ridiculous that Netgear's Orbi app STILL has this problem after more than 2 YEARS!
https://community.netgear.com/t5/Orbi-App/Orbi-App-Android-phone-quot-login-timed-out-please-try-again/m-p...
beckss1
Oct 31, 2022Tutor
Hi
Same issue after 4 year, that Orbi worked (RBR40).
All work fine on iPhone's wife
Thanks
Oct 31, 2022Guru - Experienced User
Submit a bug report:
- wsalopekOct 31, 2022Guide
Same here - can't login via the Android app. Very frustrating. RBR50 and two satellites. Pixel 6 Pro, Android 13.
I've uninstalled/reinstalled, and rebooted more times than I can count, which in itself is quite irritating because the hardware takes so long to boot up.
Another frustrating issue is being auto-logged out of the web interface seemingly every couple minutes. There's no way to change this? Huh?
And advertising in the web interface?
I had just switched from Asus mesh because of poor performance (but the app works and the settings pages and features are MUCH better than Netgear), only to find on the FIRST DAY of using a Netgear product that not only is its performance mediocre at best, but I can't even log into the app! Yeesh.
QUOTE: Submit a bug report:
Those instructions are only if a person can get into the app. Good grief.
