Royalh13
Oct 28, 2022Star
Can't logon to Orbi - "Logon timed out, please try again" - FIXED!
It is ridiculous that Netgear's Orbi app STILL has this problem after more than 2 YEARS!
https://community.netgear.com/t5/Orbi-App/Orbi-App-Android-phone-quot-login-timed-out-please-try-again/m-p...
Oct 31, 2022Guru - Experienced User
You can still submit the bug.
You'll need to contact NG support and let them know your having problems.
https://my.netgear.com/support/contact.aspx
Have you tried a full on factory reset and setup from scratch on the RBR using a wired PC and web browser or try a NEW SET up from with in the Orbi app after you've uninstalled the app and re-installed the app?
Thought NH app, same principle method to see if the app can gain access to the RBR.
Try a different mobile device with Orbi app?
Be ware of this as well for Apple devices:
Blanca_O
Oct 31, 2022NETGEAR Employee Retired
Hi Orbi Community,
We are looking into the Anywhere access issue. We will let you know for any updates.
Blanca
Community Team
