Royalh13
Oct 28, 2022Star
Can't logon to Orbi - "Logon timed out, please try again" - FIXED!
It is ridiculous that Netgear's Orbi app STILL has this problem after more than 2 YEARS!
https://community.netgear.com/t5/Orbi-App/Orbi-App-Android-phone-quot-login-timed-out-please-try-again/m-p...
jtcommunity
Oct 31, 2022Star
If it was that easy to solve the login problem everybody is facing here, somebody would have found that solution already. No no, neither uninstalling, removing cache, restarting phone nor anything else regarding the app and phone is working. The problem is inside the app. As I mentioned already: IOS version works with local connection, Android app doesn’t. Android only works if I activate “anywhere access” on IOS version and then start the Android app. It then connects via “anywhere access” automatically. If you switch from there to local access again the error message will appear on logon again.
My guts tell me the solution lies somewhere in Android version compatibility, as people in this thread have mentioned that the app is working on older phones (but perhaps that’s also older versions of the app?). Would be great if NG could accept that this really is a programming error somehow…
CrimpOn
Oct 31, 2022Guru - Experienced User
I agree completely. Behavior varies depending on Android version:
- Samsung Galaxy S6-Lite. Android version 12. Orbi app 2.20.2.2506
Opening the app brings up the "Log in with 'admin' and password.
"Login Timed Out appears almost immediately upon selecting Login" which indicates that it did not wait very long (if at all).
Since the user cannot get past this point, there is no option to use Anywhere Access (which IS enabled on this router). - Sony Xperia XZ2 Compact. Android version 10. Orbi app 2.20.0.2506
Opening the app results in connection using Anywhere Access. Says that local connection is available.
Selecting the Local option results in "Invalid Password entered", even though the password is clearly correct. - Moto e4. Android version 7.7.1 Orbi app 2.20.0.2506
Both Anywhere Access and Local access work as expected.
My typical investigation technique is to download a previous version from APK Mirror and see if it works. In this instance, those downloads are not installing (claiming file 'invalid').
What a bother.
