Royalh13
Oct 28, 2022Star
Can't logon to Orbi - "Logon timed out, please try again" - FIXED!
It is ridiculous that Netgear's Orbi app STILL has this problem after more than 2 YEARS!
https://community.netgear.com/t5/Orbi-App/Orbi-App-Android-phone-quot-login-timed-out-please-try-again/m-p...
Heavymisterd
Nov 01, 2022Initiate
Dear community team,
The everywhere Access also does not work for me. The app hangs when I try it and I need to kill the app before I can try anything else. The only solution on Android is using an old version. I know for certain that Android 10 is working and 12 and 13 are not working. I do not have a device with Android 11 to see if that version is still operational.
But even if this option would have worked, the local option should also work. I normally do not have an option active that gives access to such a important service through the internet, that is for me a security issue. I have activated it (through the app on Android 10) to test it. I have my own VPN which I use to logon to my home network and then use the local options to access whatever is needed.
As you can see, we have tried it all, clearing the cache, clearing the data, un- and reinstalling the app even a complete factory reset of the device (which should not be needed, but okay) and nothing fixes this issue.
So I suggest you take a close look at the application and test it on all the different Android versions that are operational at the moment to make sure that app works as it should.
Thank you
Duncan
DamonEdwards
Same with us. Wife and I are on Android and we can't access on either phone (Samsung Galaxy S10 and Google Pixel 6). We've checked firmware and rebooted, etc to no avail. What gives? Web interface works fine, but no access to the parental controls we paid for. It feels like we're using an app from 2012, not 2022 - I swear, isn't this the latter part of 2022???!! Ugh, good grief indeed.
