Royalh13
Oct 28, 2022Star
Can't logon to Orbi - "Logon timed out, please try again" - FIXED!
It is ridiculous that Netgear's Orbi app STILL has this problem after more than 2 YEARS!
https://community.netgear.com/t5/Orbi-App/Orbi-App-Android-phone-quot-login-timed-out-please-try-again/m-p...
Keithdb-
Nov 05, 2022Initiate
Turn off your phone's Wi-Fi so that the Orbi app is forced to connect through your mobile network and Orbi Anywhere Access. After successfully connecting without utilizing your Wi-Fi the problem seems to resolve itself. You can then turn Wi-Fi back on and connect normally.
shawn_c
Switching Wi-Fi back on won't switch back to a local connection. If you open the menu in the app, it will show the connection method at the top and allow you to switch between Anywhere and Local. Attempting to switch back to local still results in the login error for me.
- jtcommunityNov 06, 2022StarI agree. Switching back to WiFi doesn't switch from Access Anywhere to local connection. Once you do that manually in the app you have the login problem again. As a said before: local connection to the router is not possible anymore with the Android app.
- HansemanNov 06, 2022Tutor
Nice with all workarounds and tips on how to solve this problem. But this is still a problem owned by Netgear and should be solved in a hurry. Why use your products if your support is in sucg a low level? I think the hardware is brilliant but on the software level they seem to hired the not so bright people?
- hcporterNov 06, 2022InitiateMy issue remains because I can't get Anywhere Access turned on. I have tried from an iPad (because I can't log on at all from my Android device) and every time I get the "something went wrong" error message.
- shawn_cNov 06, 2022Initiate
hcporter wrote:
My issue remains because I can't get Anywhere Access turned on. I have tried from an iPad (because I can't log on at all from my Android device) and every time I get the "something went wrong" error message.Even with wi-fi turned off? With wi-fi turned off, it should force you to an Anywhere connection where you use your Netgear login.
