Royalh13
Oct 28, 2022Star
Can't logon to Orbi - "Logon timed out, please try again" - FIXED!
It is ridiculous that Netgear's Orbi app STILL has this problem after more than 2 YEARS!
https://community.netgear.com/t5/Orbi-App/Orbi-App-Android-phone-quot-login-timed-out-please-try-again/m-p...
jtcommunity
Nov 06, 2022Star
I agree. Switching back to WiFi doesn't switch from Access Anywhere to local connection. Once you do that manually in the app you have the login problem again. As a said before: local connection to the router is not possible anymore with the Android app.
Hanseman
Nov 06, 2022Tutor
Nice with all workarounds and tips on how to solve this problem. But this is still a problem owned by Netgear and should be solved in a hurry. Why use your products if your support is in sucg a low level? I think the hardware is brilliant but on the software level they seem to hired the not so bright people?
