Royalh13
Oct 28, 2022Star
Can't logon to Orbi - "Logon timed out, please try again" - FIXED!
It is ridiculous that Netgear's Orbi app STILL has this problem after more than 2 YEARS!
https://community.netgear.com/t5/Orbi-App/Orbi-App-Android-phone-quot-login-timed-out-please-try-again/m-p...
KeenEye
Nov 10, 2022Tutor
NetGear Needs to fix this ASAP. I'm unable to access the app on my Samsung device! It works on my wife's Apple device okay. It looks like the Orbi App doesn't like the new security patch on Android devices.
- michaelkenwardNov 10, 2022Guru - Experienced User
Not really. The same fault is there on ancient, unpatched Androids.
- KeenEyeNov 10, 2022Tutor
Oh Really? I thought I started to have this issue since my phone was updated. I've submitted a bug report from my app as a lot of others had done. I hope NetGear fixes this ASAP. As I mentioned in my post, this issue is definitely only on my Android device. The App works on Apple devices.
I find that Android updates can also provoke app updates.
Maybe that happened to you.
